Cyberchill's avatar
Apr 07, 2022
MR60 - Youtube slow to load
When I open youtube, there is a delay before the ad or content loads.  This may be 15-30 seconds or more.  This happens regardless of if it is a computer or a mobile device on the wifi network.  When I disconnect and go with 5G on my phone, there is no delay. This does not seem to impact other streaming content (Netflix, Disney+ etc.).
I assume there is some setting that I need to change (or not, if it is protecting me).  Looking for advice.
Thanks!
(NOTE: Posted in wrong group.  Reposting in the right place, sorry!)
  • plemans's avatar
    Apr 07, 2022
    that fibre is connected to some ONT.
    What ONT is it?
    Do you have IPv6 enabled?
    Are you using netgear armor, parental controls?
    Have you tried using a different dns from the stock one? you can try googles at 8.8.8.8 or 8.8.4.4
  • FURRYe38's avatar
    • Cyberchill's avatar
      Cyberchill
      Tutor
      Running the latest: V1.1.6.122_2.0.58
      I have FTH which goes straight into the Router.  There is no modem.
      Thanks!
      • plemans's avatar
        What ONT is it?
