shiekh
Dec 26, 2016Guide
FVS-318N; FVS-318Gv2 and Arris
User SamirD may have found a correlation in this long saga of the FVS-318N and FVS-318Gv2 not managing a cold boot. It may have something to do with being connected to an Arris modem; one easy 'fix' ...
- Feb 27, 2017
Very interesting that a router in between is getting these units working correctly.
And it's not the cable modem, but the configuration of the head-end equipment by the isp, typically made by Arris.
Does anyone have a Frys nearby? This $20 managed switch might be able to act as the filter and allow the 318G to work normally:
Or order it from newegg:
These managed switches should be able to 'filter' the packets even if they aren't using any other managed switch options. Cheap fix to the problem.
Rastan
Jan 22, 2017Aspirant
Yeah. You'd think they would of released a firmware update by now. Truthfully has led me to recommend against buying Netgear.
shiekh
Jan 22, 2017Guide
Don't get me started... ;-)
- neechFeb 27, 2017Aspirant
I am having this exact issue and I am behind a netgear CM600 (cable modem). I am running the latest firmware on the router 4.3.4-2.
So, apparently I need another router to go inbetween my cable modem and my VPN router? That's not conveinent at all...
neech
- shiekhFeb 27, 2017Guide
Worked fine for me (with a protective router); looking forward to learn if it works for you.
- RastanFeb 27, 2017Aspirant
Seems silly that you have to put an additional pience of gear between this gear when it is obviously caused by faulty firmware since it worked in the past.
- SamirDFeb 27, 2017Prodigy
I aggree it is silly to need a intermediate device.
I am almost half-inclined to just replace the thing with something that actually works...
