shiekh
Dec 26, 2016Guide
FVS-318N; FVS-318Gv2 and Arris
User SamirD may have found a correlation in this long saga of the FVS-318N and FVS-318Gv2 not managing a cold boot. It may have something to do with being connected to an Arris modem; one easy 'fix' ...
- Feb 27, 2017
Very interesting that a router in between is getting these units working correctly.
And it's not the cable modem, but the configuration of the head-end equipment by the isp, typically made by Arris.
Does anyone have a Frys nearby? This $20 managed switch might be able to act as the filter and allow the 318G to work normally:
Or order it from newegg:
These managed switches should be able to 'filter' the packets even if they aren't using any other managed switch options. Cheap fix to the problem.
shiekh
Mar 04, 2017Guide
Except LiveSecurity Service needs to be paid for annually, so the low purchase price is a bit deceptive.
The SG-1000 looks like fun; what has pfSense gold got that the free version does not?
SamirD
Mar 04, 2017Prodigy
shiekh wrote:Except LiveSecurity Service needs to be paid for annually, so the low purchase price is a bit deceptive.
But even without live security, the Watchguard unit will run circles around the fvs318 at that price. We actually replaced our main router years ago with an xtm22w. While it was limited on throughput (could do 45Mbps at best wan to lan), it had up times of over 80 days regularly without a hiccup even when everything else like cable modems did. We recently replaced the xtm22w with an m200 that we got for a steal. I'm tempted to buy that t10 unit just to use at home--they're that stout, and the support is a real person that knows what they're doing. I had to call them on a few issues on our m200 and was able to talk to them 'on the level', not dummied down as in the smb world. It's enterprise gear with enterprise support, and that usually comes at an enterprise price unless you know where the deals are.
- shiekhMar 04, 2017Guide
Maybe I am spoilt, but I expect an uptime way better than just 3 months
- SamirDMar 08, 2017Prodigy
Those are hard shoes to fill in the smb world. I usually have some sort of hiccup on carrier equipment that causes issues with a router and causes the router to need to be rebooted too.
