shiekh
Dec 26, 2016Guide
FVS-318N; FVS-318Gv2 and Arris
User SamirD may have found a correlation in this long saga of the FVS-318N and FVS-318Gv2 not managing a cold boot. It may have something to do with being connected to an Arris modem; one easy 'fix' ...
- Feb 27, 2017
Very interesting that a router in between is getting these units working correctly.
And it's not the cable modem, but the configuration of the head-end equipment by the isp, typically made by Arris.
Does anyone have a Frys nearby? This $20 managed switch might be able to act as the filter and allow the 318G to work normally:
Or order it from newegg:
These managed switches should be able to 'filter' the packets even if they aren't using any other managed switch options. Cheap fix to the problem.
shiekh
Apr 29, 2017Guide
From the release notes
Bug Fixes:
* Fixed the device crash issue
looks promsing, as the original problem was a crash after about 5 mins
shiekh
Apr 30, 2017Guide
Some more detail that may help
On a cold boot, after about 5 mins (on 4.3.5-3) one can surf the internet for a short time; this does not last long and it comes back up permanently at around 12 mins.
This may help a lot of people who see it fail and don't wait.
