jossiestone
Aug 23, 2017Tutor
fvs318 drop wireless
The FVS318N is dropping wireless network. I found the following line in the event log: [FVS318N][Local0-wireless][UDOT11] umiIoctl(UMI_COMP_KDOT11,2 ,39) failed This error is shown often in the ev...
jossiestone
Aug 24, 2017Tutor
- May I know how many devices are connected to the wireless network?
Sure, at this moment there are 6 devices connected to wifi.
- Is it only happening to specific devices?
Mobile phone not noticed, (switch automatic to 4g when no wifi) Laptop, Ipad has issue's once to several times per day.
- Is your firewall is up to the latest firmware version?
Firmware Version: 4.3.5-3
Deleted the logfile the last time. Now I have this in the logfile:
Thu Aug 24 21:00:18 2017(GMT+0100) [FVS318N][Kernel][KERNEL] <sppe_cmd_arp> Fail to delete IPv4 ARP entry
Thu Aug 24 21:00:03 2017(GMT+0100) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data
Thu Aug 24 20:59:47 2017(GMT+0100) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data
Thu Aug 24 20:59:32 2017(GMT+0100) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data
Thu Aug 24 20:59:17 2017(GMT+0100) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data
Thu Aug 24 20:59:02 2017(GMT+0100) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data
Thu Aug 24 20:58:47 2017(GMT+0100) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data
Thu Aug 24 20:40:22 2017(GMT+0100) [FVS318N][Local0-wireless][UDOT11] umiIoctl(UMI_COMP_KDOT11,2 ,39) failed
JohnC_V
Aug 24, 2017NETGEAR Employee Retired
What seems to be happening on the wireless network? The logs showing is actually part of the operating system and not a problem from your network. Please try resetting the firewall to factory default then reconfigure the wireless network.
