jossiestone
Aug 23, 2017Tutor
fvs318 drop wireless
The FVS318N is dropping wireless network. I found the following line in the event log: [FVS318N][Local0-wireless][UDOT11] umiIoctl(UMI_COMP_KDOT11,2 ,39) failed This error is shown often in the ev...
JohnC_V
Aug 29, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
jossiestone
Aug 29, 2017Tutor
Trying to find a good timeslot to do the reset of the device.
