janty1977
Sep 04, 2017Aspirant
FVS318 ProSafe VPN Firewall
Help,how can I connect this to my home router plz, thanks in advance
JohnC_V
Sep 06, 2017NETGEAR Employee Retired
Hi janty1977,
Welcome to the community!
It seems that you already have a router and you want this firewall to be added to your network. May I know which one do you wanted to set as the main router? You may add the firewall by changing its local LAN IP to 192.168.2.0/24 network so that it will not cause any conflict with your existing router or you may change your existing router to 192.168.2.0/24. If you wanted your existing router to work as your main, then you will be losing the advantage of using a firewall. But then again, it will still work.
If this is a brand new firewall, I may suggest you to open a chat / case online on NETGEAR support as you do have a 90 days free support. We can take advantage of that so that we can help you setting up your new firewall.
- janty1977Sep 07, 2017Aspirant
Hi, thanks for the reply.
I am new to all this and a bit wet behind the ears. How do i do the above instructions and could i have a step by step guide or process please. I originally bought this product so it would provide me a continuous VPN for streaming etc.
I bought the FV318 2nd hand in a used condition with all the leads and help disc, but still having problems.
Thanks again in advance. Jiohn
- JohnC_VSep 07, 2017NETGEAR Employee Retired
I see. I don't think that you are getting what this VPN firewall can do. Maybe you are referring for the VPN software and not the hardware itself so that you can browse video streaming which is blocked from your location. You may try to check this.
Sorry if I was sounding a bit silly in previous post. Yes I would like to use this as a firewall router and a VPN device as I will be plugging my IPTV box into it with a ethernet cable but still using my home router for other devices. I just can't configure it to connect up to my existing router.
Is this possible?
