janty1977
Sep 04, 2017Aspirant
FVS318 ProSafe VPN Firewall
Help,how can I connect this to my home router plz, thanks in advance
janty1977
Sep 07, 2017Aspirant
Hi, thanks for the reply.
I am new to all this and a bit wet behind the ears. How do i do the above instructions and could i have a step by step guide or process please. I originally bought this product so it would provide me a continuous VPN for streaming etc.
I bought the FV318 2nd hand in a used condition with all the leads and help disc, but still having problems.
Thanks again in advance. Jiohn
JohnC_V
Sep 07, 2017NETGEAR Employee Retired
I see. I don't think that you are getting what this VPN firewall can do. Maybe you are referring for the VPN software and not the hardware itself so that you can browse video streaming which is blocked from your location. You may try to check this.
