Tridac
Dec 22, 2018Aspirant
FVS318: Unable to log in after reset defaults
Hi,
I have an FVS318 which I need to bridge two subnets, last used as a internet router. Can't remember if the f/ware is stcock, or has been upgraded at some stage. Have a laptop connected to o...
- Dec 28, 2018
Hi Tridac,
Welcome to our community! :)
It seems that the firewall isn't responding to http request. Please try to reset it to factory default and also try to use another PC to isolate the issue.
JohnC_V
Dec 28, 2018NETGEAR Employee Retired
Hi Tridac,
- TridacFeb 10, 2019Aspirant
Hi,
A bit late getting back to this, apologies. Fixed it by replacing the network cable, fault in one pair. Nothing wrong with the router :-)...
Chris
