AMP123's avatar
AMP123
Changing Default Network EX3700
I'm trying to connect my EX3700 range extender to an existing network with a range 192.168.68.x
I can see and connect to my existing SSIDs on the EX3700, but it insists on using it's preferred range 192.168.1.x to try and pick up DHCP and DNS etc via it's own gateway 192.168.1.250
Is there a way to change the default network of the EX3700?
  • I dug the EX3700 out of my "Box of Stuff".  Oh, my.  Things have changed since 2018 when this device came on the market.  WiFi extenders are so inexpensive now that I would be likely to purchase a modern one.  Anyway....
    Can you verify how this page appears on your EX3700:
  • CrimpOn's avatar
    CrimpOn
    Is this EX3700 in Extender Mode or Access Point mode?
      • CrimpOn's avatar
        CrimpOn
