DennisT1
Dec 08, 2015Aspirant
FVS318G - Weird problem
Works fine most of the time. Very infrequently the following happens - Remote (WAN) access to LAN email server begins failing. LAN systems cannot get out to the WAN. This includes the FW. FW di...
JohnRo
Dec 08, 2015NETGEAR Employee Retired
Hi DennisT1,
Are you getting any error messages when the email server begins failing? Did you check the logs of the firewalls and see any unusual entries?
Looking forward to your response.
Thanks,
DennisT1
Dec 09, 2015Aspirant
Nothing unexpected appears in the logs of any of the LAN devices.
My 1st thought was the problem rests with the Comcast router. However it has been replaced with a newer one and the problem is still happening. My next step appears to be to replace the 318 with a pfsense FW if I can't get this sorted out.
- JohnRoDec 09, 2015NETGEAR Employee Retired
Hi DenniT1,
What firmware version is the FVS318G running? I think it is best to run a traceroute and see where the internet breaks, kind of weird though when VPN and RDP still working.
Thanks,
- DennisT1Dec 16, 2015Aspirant
I ended up replacing it with a pfsense box.
