glocker
Dec 03, 2010Aspirant
FVS318G DMZ and correct rules
Hi there, I searched through all the postings and couldn't find anything that seemed to fit my simple issue. We have a project where we need to have 3 machines in front of the FVS318G so those 3 m...
glocker
Dec 16, 2010Aspirant
I tried to make an inbound DMZ WAN rule to allow everything and based on your suggestion of
"in the inbound you wil not use actual DMZ server IP you use in the dmz setting section, you need to se any IP which will be the DHCP range you choose to use in the DMZ settings"
I used the IP address 192.168.10.100 for the "DMZ Server IP address" box that the rule asks for. DMZ is 192.168.10.1 and the clients are 192.168.10.100 thru 10.110.
But that did not work. The port still showed as blocked and was not allowed through to the client machines on the DMZ.
