ChunLee
Sep 07, 2015Aspirant
FVS318G Port Forward Fail
Hi All, I cannot forward port 5901-5903, those port use for remote the client PC with UltraVNC. - Set the 3 ports on different service name. - Set signle inbound rule for each port. Can ...
JohnRo
Sep 07, 2015NETGEAR Employee Retired
Hello ChunLee,
Welcome to the community!
I have some questions for us to isolate your issue properly. I have listed them below:
1.Are you getting any error messages upon opening the ports?
2. What is the firmware version you are currently using?
I also would like to request for sreenshots (firewall rules) to be sent to me through PM.
I'll look forward to your response.
Thanks,
- ChunLeeSep 07, 2015Aspirant
Dear JohnRo
No error to opening the port, the firmware version is 4.3.3-3.
- JohnRoSep 07, 2015NETGEAR Employee Retired
Hi ChunLee,
The settings looks good, try changing the WAN users to "ANY" and see if it will make any ddiference. What modem are you using?
Thanks,
Hi JohnRo,
I have tried set the WAN users to "ANY" already, aslo checked the the setting on UltraVNC is fine. I tred set the port forward on Netgear JNR3210 is work. So, I don't have any idea. The modem is provided by service provider, I have no idea what modem.
Best Regards,
Chun Lee
