ChunLee
Sep 07, 2015Aspirant
FVS318G Port Forward Fail
Hi All, I cannot forward port 5901-5903, those port use for remote the client PC with UltraVNC. - Set the 3 ports on different service name. - Set signle inbound rule for each port. Can ...
ChunLee
Hi JohnRo,
I have tried set the WAN users to "ANY" already, aslo checked the the setting on UltraVNC is fine. I tred set the port forward on Netgear JNR3210 is work. So, I don't have any idea. The modem is provided by service provider, I have no idea what modem.
Best Regards,
Chun Lee
ChunLee
Sep 08, 2015Aspirant
Hi JohnRo,
May I ask what is different between NAT and Classical Routing Interfaces?
Thank you?
Best Regards,
Chun Lee
- JohnRoSep 08, 2015NETGEAR Employee Retired
Hello ChunLee,
NAT(Network Address Translation) and Classical routing both performs routing from WAN to LAN. You usually use NAT when the ISP gives you a single IP address, what NAT does is convert the Public IP (IP given by ISP ex. 98.245.153.xxx) to local/private IP (192.168.1.x). Classical Routing is almost the same but it is routing withour NAT, you use this when the ISP gives you multiple public IP addresses - you will be able to use the public IPs directly to the PCs or devices, it eliminates the translation part, instead of giving the devices a local/private IP each device gets a public IP address.
Which one of these routing features are you using?
I'll look forward to your response.
Thanks,
- ChunLeeSep 08, 2015Aspirant
Dear JohnRo,
I set the ISP as NAT mode.
Best Regards,
Chun Lee
- JohnRoSep 09, 2015NETGEAR Employee Retired
Hello ChunLee,
Another question on this one, have you tested forwarding other ports like RDP or HTTP? I need to know if other port forwarding rules have worked, for us to isolate your issue further. I also noticed that you have also checked "Translate to Port number", can you post a screenshot of the "services" tab?
Thanks,
