JB_Morgy
Jul 31, 2016Aspirant
FVS318G really slow internet speed
My internet speed from my ISP is 50mbps. If I connect my modem directly to my computer, I get 50mbps download speeds. But as soon as I connect the modem to my ProSafe FVS318G, the speed drops to on...
- Aug 01, 2016
Hi JB_Morgy,
Welcome to the community! :)
I believe that the FVS318G you have is a version 1. The LAN-to-WAN Throughput of the FVS318Gv1 is 25Mbps which is lower than 50Mbps that you have subscribed from your ISP. What you need is a VPN firewall router that has a higher LAN-to-WAN Throughput than 50Mbps like the FVS318Gv2. Also, make sure that the modem is set to full-bridge mode so that the WAN IP Address will be registered to the VPN firewall router.
Other than the FVS318Gv2, you may also check the FVS318N, FVS336Gv3 and SRX5308 on the data sheet here.
DaneA
NETGEAR Community Team
DaneA
Aug 01, 2016NETGEAR Employee Retired
Hi JB_Morgy,
DaneA
- JB_MorgyAug 01, 2016Aspirant
Yep, that was exactly the problem...mine was Version1. Just purchased a FVS318Gv2 today, just got it hooked up and lo and behold, I'm hitting 56mbps now!!!!
FWIW, you can easily tell if you have v2, because the web interface screen shows it as "NETGEAR ProSafe™ Gigabit 8 Port VPN Firewall FVS318Gv2". Simple as that. If it doesn't show "v2", then it's version1.
So for any other users out there that have v1 and can't seem to get the speed your ISP says you should be getting, the problem is not the ISP...it's your version 1 router which has a MAXIMUM throughput speed of 25mbps. Purchase a version2 router, which has a throughput speed of 250mbps.
JB
- DaneAAug 02, 2016NETGEAR Employee Retired
Hi JB_Morgy,
I'm glad that the problem got resolved using the FVS318Gv2. :) I appreciate that you have shared your experience here in the community.
Feel free to post your future concerns here in the community.
DaneA
