sndk4asp
Apr 11, 2016Aspirant
FVS318Gv1 connected to a FVS318Gv2
Hello. I have a question about the two models in the subject. My network was so composed: Net A) One FVS318G directly connected to Internet with static IP. Local lan IP 192.127.0.0/24 It was u...
- Apr 19, 2016
What are you using for the ike and vpn profiles in terms of md5/des, etc? Set each one to the lower possible setting on both routers and see what happens. Disable all dpd on both sides for now. Let's see if we can get the tunnel up and then increase security until it breaks again.
SamirD
Apr 12, 2016Prodigy
Try using aggressive vs main mode on both ends. I've had problems like this resolved on various brands by changing this setting.
- sndk4aspApr 13, 2016Aspirant
Thanks SamirD, I have applied your suggestion and now the logs (taken from the v2) shows this:
Wed Apr 13 16:26:34 2016 (GMT +0200): [FVS318Gv2] [IKE] ERROR: invalid ID payload.
Wed Apr 13 16:26:34 2016 (GMT +0200): [FVS318Gv2] [IKE] WARNING: ID value mismatched.
Wed Apr 13 16:26:34 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: DPD
Wed Apr 13 16:26:34 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
Wed Apr 13 16:26:34 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: KAME/racoon
Wed Apr 13 16:26:32 2016 (GMT +0200): [FVS318Gv2] [IKE] ERROR: invalid ID payload.
Wed Apr 13 16:26:32 2016 (GMT +0200): [FVS318Gv2] [IKE] WARNING: ID value mismatched.
Wed Apr 13 16:26:32 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: DPD
Wed Apr 13 16:26:32 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
Wed Apr 13 16:26:32 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: KAME/racoon
Wed Apr 13 16:26:25 2016 (GMT +0200): [FVS318Gv2] [IKE] ERROR: invalid ID payload.
Wed Apr 13 16:26:25 2016 (GMT +0200): [FVS318Gv2] [IKE] WARNING: ID value mismatched.
Wed Apr 13 16:26:24 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: DPD
Wed Apr 13 16:26:24 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
Wed Apr 13 16:26:24 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: KAME/racoon
Wed Apr 13 16:26:22 2016 (GMT +0200): [FVS318Gv2] [IKE] ERROR: invalid ID payload.
Wed Apr 13 16:26:22 2016 (GMT +0200): [FVS318Gv2] [IKE] WARNING: ID value mismatched.
Wed Apr 13 16:26:22 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: DPD
Wed Apr 13 16:26:22 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
Wed Apr 13 16:26:22 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Received Vendor ID: KAME/racoon
Wed Apr 13 16:26:21 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Configuration found for 88.14x.xxx.xxx.
Wed Apr 13 16:26:21 2016 (GMT +0200): [FVS318Gv2] [IKE] INFO: Using IPsec SA configuration: 192.127.0.0/24<->192.127.1.0/24
