sndk4asp
Apr 11, 2016Aspirant
FVS318Gv1 connected to a FVS318Gv2
Hello. I have a question about the two models in the subject. My network was so composed: Net A) One FVS318G directly connected to Internet with static IP. Local lan IP 192.127.0.0/24 It was u...
- Apr 19, 2016
What are you using for the ike and vpn profiles in terms of md5/des, etc? Set each one to the lower possible setting on both routers and see what happens. Disable all dpd on both sides for now. Let's see if we can get the tunnel up and then increase security until it breaks again.
sndk4asp
Apr 19, 2016Aspirant
No effect :(
SamirD
Apr 19, 2016Prodigy
