synoptics
Dec 06, 2015Guide
FVS318Gv2 - Not NAT routing non-local subnet traffic to internet
I have an existing setup that works just fine, but need to upgrade to devices that support 1G interfaces to take advantage of an upgraded Internet speed (150Mb/s). The existing network looks like thi...
- Dec 14, 2015
The solution to my problem was to send the FVS318Gv2 back to Amazon and load opensource firmware (shibby tomato) on my WNR3500Lv2.
BrianL2
Dec 06, 2015NETGEAR Employee Retired
Hi synoptics,
There shouldn't be a problem with this setup. Would you mind if you will create two VLANs on the FVS318Gv2 on different subnets instead?
Kind regards,
BrianL
NETGEAR Community Team
synoptics
Dec 06, 2015Guide
That's not practical in my network. The FVS318Gv2 is in a wiring closet on the other side of the building of where the layer-3 switch (connecting to the cluster of servers) reside. It is also two layer-2 switch hops away.
