synoptics
Dec 06, 2015Guide
FVS318Gv2 - Not NAT routing non-local subnet traffic to internet
I have an existing setup that works just fine, but need to upgrade to devices that support 1G interfaces to take advantage of an upgraded Internet speed (150Mb/s). The existing network looks like thi...
- Dec 14, 2015
The solution to my problem was to send the FVS318Gv2 back to Amazon and load opensource firmware (shibby tomato) on my WNR3500Lv2.
DaneA
Dec 09, 2015NETGEAR Employee Retired
Hi synoptics,
At least we know that LAN Multi-Homing works on your FVS318Gv2. Going back to your concern, you have already contacted NETGEAR Support about it. Have you already forwarded the configuration file of both WGR614v9 and FVS318Gv2 to NETGEAR Support to be analyzed and for comparison as well? If not yet, I advised you to download the configuration file of both WGR614v9 and FVS318Gv2 as well as the Layer 3 switch then attached it to your open case with NETGEAR Support.
DaneA
NETGEAR Community Team
synoptics
Dec 14, 2015Guide
- DaneADec 14, 2015NETGEAR Employee Retired
Hi synoptics,
Thanks for the follow-up and sharing the solution that you performed. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
