TCD-Experea
Dec 11, 2016Aspirant
FVS318Gv2 fails PCI-DSS scans
We use these for gateway to gateway vpn connections between remote offices and the main office. No real issues there now, until they failed a Trustwave scan because of Netgear's built-in certificate ...
- Dec 16, 2016
OK we passed today with this firmware and a written adendum to cover use of L2TP tunnel that Trustwave doesn't like even though it is secured. Had to literally turn off everything else in the way of remotely connecting to these to manage them.
My management solution is to setup VPN access at all locations and only manage them through the tunnel at the moment... seems to wok, but a failure will lead to about 2 hourss of downtime while I travel to a site with a replacement device. I do have a spare that I can configure to match in about 15 minutes now since I've done it so many times.
TCD-Experea
Dec 12, 2016Aspirant
Firmware is 4.3.4-2 on all 3 devices.
I have disabled remote admin at this point and have asked AP/AR to initiate a new scan.
DaneA
Dec 12, 2016NETGEAR Employee Retired
Hi TCD-Experea,
Let us know how the new scan goes.
Also, you may want to try to downgrade the firmware to v4.3.3-8. As per release notes of firmware v4.3.3-8, one of the bug fixes mentioned about PCI Compliance Scans. You can download the firmware here. Be reminded that its recommended to perform a factory reset after downgrading the firmware then reconfigure it from scratch and check if same problem will occur.
DaneA
NETGEAR Community Team
