TCD-Experea
Dec 11, 2016Aspirant
FVS318Gv2 fails PCI-DSS scans
We use these for gateway to gateway vpn connections between remote offices and the main office. No real issues there now, until they failed a Trustwave scan because of Netgear's built-in certificate ...
- Dec 16, 2016
OK we passed today with this firmware and a written adendum to cover use of L2TP tunnel that Trustwave doesn't like even though it is secured. Had to literally turn off everything else in the way of remotely connecting to these to manage them.
My management solution is to setup VPN access at all locations and only manage them through the tunnel at the moment... seems to wok, but a failure will lead to about 2 hourss of downtime while I travel to a site with a replacement device. I do have a spare that I can configure to match in about 15 minutes now since I've done it so many times.
TCD-Experea
Dec 16, 2016Aspirant
SamirD
Dec 18, 2016Prodigy
I was going to suggest vpn tunnels and managing them that way. And one way to avoid the drive in case one hangs up for some reason is a cheap $99 rebooter from 3gstore that we've found to work great. We actually have a terrible 'business class' cable modem from charter on one of our connections that every so often gets a glitch in it that only blocks the ipsec tunnel from working. A reboot quickly fixes it, so we've programmed the rebooter to reboot that modem whenever it loses pings across the tunnel, and it's handled the problem since charter won't replace the modem since they think it's fine. It's worth a look at out of band tools like this if a long drive is going to cost.
