Mac_D12
Apr 21, 2018Follower
FVS318Gv2 Slow Internet Speed
Just noticed i am not getting close to 150Mbps download speed on my comcast plan. I have a Netgear CM1000 Modem, linked to FVS318Gv2, which goes into a NightHawk 7000 wireless router. Download spee...
schumaku
Aug 29, 2018Guru - Experienced User
Ricky, Is this a DSL PPPoE connection (where the FVS318Gv2 does have some limitations as per the referenced forum thread) or CableTV Internet (and no PPPoE)?
rickgode
Aug 30, 2018Aspirant
It is cable internet. Under the Network Configuration/Wan Settings/ISP Type I have selected PPTP.
So I guess no PPPoE?
Ricky
- schumakuAug 30, 2018Guru - Experienced User
...but similar problem, no hardware accelerated protocol optimizations in place for these PPPoE or PPTP on these devices.
- rickgodeSep 03, 2018Aspirant
So does that mean with the FVS318Gv2 I won't be able to achieve 200mbps?
- SamirDOct 24, 2018Prodigy
Yep, if this is the issue then it won't be able to hit 200Mbps.
It's been a few years since I looked at the 318G specs, but I think some versions were just limited to just 60Mbps if I recall.
A logical and easy upgrade path would be the FVS318N and just shut off the wireless. I have seen 350Mbps down on ours and I don't think that's the limit.
