djqkat
Apr 04, 2017Aspirant
FVS318Gv2: TCP: too many of orphaned sockets and question with IP/MAC Binding
Hi there, yesterday I configured my new FVS318Gv2 and I have 2 questions. 1. In the log I see a lot of "TCP: too many of orphaned sockets" messages which I think is not a good thing. Togethe...
DaneA
Jun 12, 2017NETGEAR Employee Retired
Hi djqkat,
Kindly answer the questions below:
a. How is everything connected? It would be best if you will post a diagram of your current network setup.
b. Have you tried to reset the FVS318Gv2 back to factory default settings then reconfigure it from scratch and check if same logs will appear?
c. What is the current firmware version of the FVS318Gv2?
DaneA
NETGEAR Community Team
- djqkatJun 12, 2017Aspirant
Hi DaneA,
a. I have a diagramm... but how can I upload it here?
b. Yes, I have tried this.
c. Have to check in the evening.
Greeting,
Robert
Hi DaneA,
I think you should get my image with this link: https://ibb.co/g5gYtF
Oh and of course the Fritzbox is connected via the WAN-Port to the FVS318Gv2.
Greetings,
Robert
Hi DaneA,
I checked the firmware version and I have version 4.3.1-11 installed. So I will make an upgrade now to the latest firmware and will write again if I there are still entries in the logfile.
Greetings,
Robert
- DaneAJun 13, 2017NETGEAR Employee Retired
Thanks for the update.
Since you have already upgrade the firmware to the latest version 4.3.5-3 and already tried to factory reset the FVS318Gv2 but still the same logs appear, it would be best that you open a chat / online case with NETGEAR Support for further assistance. Kindly submit a copy of the logs you encountered on the FVS318Gv2 via the chat / online case and this will be forwarded to our engineering team for it to be analyzed.
DaneA
- djqkatJun 13, 2017Aspirant
Hi DaneA,
okay, thank you. I will do that and post the results.
Greetings,
Robert
