Johnny-Mac
Feb 27, 2018Aspirant
FVS318Gv2 unavailable?
I'm having a bear of a time finding this on any stores, even Amazon. Any ideas? Thanks
- Mar 01, 2018
Thank you for still considering the ProSAFE routers. We appreciate valued customers like you. Unfortunately, yes, and there still no announcement if they will still be producing one.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Johnny-Mac
Mar 01, 2018Aspirant
Thank you for the reply. It appears I missed that memo. That's too bad, the FVS lineup was my go-to router for over a decade. I'm not aware of any other ProSAFE routers, so it appears you're pulling out of the business router space altogether?
JohnC_V
Mar 01, 2018NETGEAR Employee Retired
