johnakajohn
Dec 20, 2015Tutor
FVS318Gv2 WAN to LAN throughput
I recently purchased an FVS318Gv2 because I needed to set up two VLANs, initial testing on my network looked good, after upgrading to the latest firmwware and resetting to defaults I had it connecting...
- Jan 22, 2016
I seem to have gotten this working via telnet and a tftp server, I've sent the output to support to verify. Bit of a roundabout route but at least it seems to work.
DaneA
Dec 21, 2015NETGEAR Employee Retired
Hi johnakajohn,
Welcome to the community! :)
As per data sheet, the LAN-to-WAN Throughput of the FVS318Gv2 is 250Mbps and of course, this may vary depending on network traffic and environment. I suggest that you kindly try to set the modem/router on full-bridge mode making it a modem-only device so that the FVS318Gv2 will be the main router. Then, check if the connection has been improved.
DaneA
NETGEAR Community Team
