johnakajohn
Dec 20, 2015Tutor
FVS318Gv2 WAN to LAN throughput
I recently purchased an FVS318Gv2 because I needed to set up two VLANs, initial testing on my network looked good, after upgrading to the latest firmwware and resetting to defaults I had it connecting...
- Jan 22, 2016
I seem to have gotten this working via telnet and a tftp server, I've sent the output to support to verify. Bit of a roundabout route but at least it seems to work.
JohnRo
Jan 22, 2016NETGEAR Employee Retired
Hello johnakajohn,
Thank you for the update, we'll check the support case and see if this is a valid workaround since we do not really suggest accessing the firewall via TelNet without the approval of the engineering team.
Thanks,
johnakajohn
Jan 23, 2016Tutor
They replied and said the method I used was valid, I closed the case and can now begin actually integrating this within my network !
- BrianL2Jan 23, 2016NETGEAR Employee Retired
Hi johnakajohn,
Thanks for you feedback. You may also close this thread by clicking the "Accept as Solution" button in one of the responses that you received.
Let me know if you have other questions.
Kind regards,
BrianL
NETGEAR Community Team
