tremble35
Mar 06, 2016Aspirant
FVS318N - Some websites not working
Hi all I becomming crazy because I have configured some open ports in the firewall, but I get only two working. Firmware Version: 4.3.3-6 First I configured HTTPS (default service) to my ma...
tremble35
Hello DaneA
Thank you for quick reply. I tried these scans and I was successfull for some moments. I got a green light for 5005 and I got a connection with my IE from outside to the NAS (5000). But now nothing is working anymore, no san is successfull and even before seen IP-Cam with my CMS is gone.
I catched a log from my FVS318N when I tried to make port scan of port 5005 what was not successfull.
Sun Mar 6 19:20:09 2016(GMT+0100) [FVS318N][Kernel][KERNEL] [FIREWALL]LOG_PACKET[DROP]IN=eth1 OUT= MAC=08:bd:43:92:bb:a7:a8:a6:68:ac:6c:80:08:00 src=141.138.203.105 DST=14.0.0.29 LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=9243 DF PROTO=TCP SPT=38641 DPT=5005 WINDOW=5840 RES=0x00 SYN URGP=0
14.0.0.29 is my WAN port. This WAN port is physically connected to a gateway from provider "Drei", it is a 3webgate from ZTE. All ports are forwarded to the 14.0.0.29 and I see the FVS receives this port scan.
IP address of gateway and dyndns are the same, is checked from my side.
Best regards Tremble35
DaneA
Mar 07, 2016NETGEAR Employee Retired
Hi tremble35,
Here are my follow-up questions:
a. Are there any changes made to your network if ever these was all working fine before?
b. If you will connect either your NAS or IP camera directly to the gateway, are you able to get Webdav access to your NAS and web-access to the IP camera since all ports are open on the gateway?
DaneA
NETGEAR Community Team
- tremble35Mar 08, 2016Aspirant
Hi DaneA
Thanks for help.
The ports are still the same in the FVS318N, no changes, but from one minute to other it is not working anymore. By the way, just two ports worked it was 443 (default service) but no exchange is anymore in the net. Second port was this cam port 34069 via CMS but is not working anymore. I have no idea how I could do anything. This cam is in the default VLAN. other cams or recorder are in VLAN2 or VLAN3 or VLAN4. VLAN routing works, becuase internal i can get all equipment.
I connected today a IP cam directly to the webgates LAN port and configured two firewall rules. One for the CAMS TCP port for CMS (34567) and one for HTTP access (8067). Immideately I got via both a connection.
Best regards
Tremble35
- DaneAMar 08, 2016NETGEAR Employee Retired
Hi tremble35,
To further isolate the problem, kindly try to configure the gateway as a modem-only device that is set to full-bridge mode. Then, connect it to the WAN port of the FVS318N. Configure the FVS318N for internet access. Then finally, check if you will be able to get Webdav access to your NAS and web-access to the IP camera since the respective ports are open on the FVS318N.
DaneA
- tremble35Mar 10, 2016Aspirant
Hello DaneA
Sorry for my late reply, but it was a difficult birth. First I had to get the latest update for my Webgate, if I used the automatic search it told me to have the latest update but without any bridge mode. Than the provider explained me I have to download the update manually, but it had the same versionsnumber as the actual FW and only after update I could see a newer version in the GUI. But before update I had to set the Webgate in factory default, because I did not get access with the update.exe
After setting bridge mode I had first to find out which only port is for the connection to the FVS. Later and after many tries I made my WAN to receive from ISP changed the VLAN DNS and setted the DDNS. So :smileyvery-happy::smileyvery-happy::smileyvery-happy: I got internet access and see: portforwarding works. I did not change anything in the firewall or service list, just settings in WAN for the bridge modus from Webgate.
I do not know which equipment has this disadvantage, but before I had just random access from outside and now I get all ports forwarded what I need. It works only under bridge mode. Unfortunately I lost one firewall now.
Thanks for help!!!
Best regards tremble35
