the_e
Nov 28, 2012Aspirant
FVS318n and 2 GS108ev2 Switches
Hi All, Example Scenario using the equipment in the title to share internet and a network printer: 7 vlans with their own ip range (dhcp served by router) Vlan 1-5 on Switch A connected via Switch ...
the_e
Hi June,
Thanks for the answer.
I know that there is the option to select "Enable Inter VLAN Routing" at the end of the "Edit VLAN profile".
The FVS318n -- Firmware version 4.2.0-14 -- does not appear to have a menu for VLAN rules.
It would still be nice to know where inter vlan routing needs to be activated -- 1) In the vlan that connects the router and the two switches together?
2) In the vlan where the printer would be?
3) In each of the other vlans that need to print?
4) If inter vlan routing is enabled in the vlans -- in the example 1,2,7, and 4 (printer in 4) -- what stops 1,2,7 communicating with eachother?
Regards
the_e
Regards
the_e
