the_e
Nov 28, 2012Aspirant
FVS318n and 2 GS108ev2 Switches
Hi All, Example Scenario using the equipment in the title to share internet and a network printer: 7 vlans with their own ip range (dhcp served by router) Vlan 1-5 on Switch A connected via Switch ...
the_e
Nov 29, 2012Aspirant
That is where I am having problems getting my head around it. There would only be one PC in each of vlans 1, 3, 7, one network printer in Vlan 4. If I understand you correctly Inter vlan routing needs to be activated on 1,3,4,7. That means that vlan 1, 2, 3, 7 will all print on vlan 4. Vlan 1 will not see Vlan 2, 3, 7 -- correct?
I would probably need another trunk vlan with its own ip subnet containing the router and the two switches. Let's call it vlan 8. VLan 8 would contain ports 1, 2 on the router and NOT have inter vlan activated?
