the_e
Nov 28, 2012Aspirant
FVS318n and 2 GS108ev2 Switches
Hi All, Example Scenario using the equipment in the title to share internet and a network printer: 7 vlans with their own ip range (dhcp served by router) Vlan 1-5 on Switch A connected via Switch ...
jmizoguchi
Nov 30, 2012Virtuoso
srxn or prosecure UTM series is what you want
you can still use inter vlan on fvs318N but i will basically open entire network to commotion across the vlan but that is not what you wanted to do
