the_e
Nov 28, 2012Aspirant
FVS318n and 2 GS108ev2 Switches
Hi All, Example Scenario using the equipment in the title to share internet and a network printer: 7 vlans with their own ip range (dhcp served by router) Vlan 1-5 on Switch A connected via Switch ...
jmizoguchi
Nov 30, 2012Virtuoso
you can still use DHCP on each vlan from fvs so you should able to use vlan settings on gs108
UTM is subscription base which offers more than prosafe does if you need more filtering capabilities.
I use UTM25
I use UTM25
