lippy
May 06, 2012Aspirant
FVS318N Can’t Port Forward
Okay. I’m throwing the uncle card. I can’t get the FVS318N to port forward. I’m trying to forward port 1723 (PPtP) for VPN into our server. I get out, I hit the server, but it is being blocked on t...
jmizoguchi
May 10, 2012Virtuoso
lippy wrote: June, Thanks for replying.
So for the the Inbound Service rule, in the WAN Destination IP Address, this should be set to the "Broadband"? Or the IP Address of the FVS318N?
REMOTE public IP that is coming from.
NOT broadband or FVS.
REMOTE... OTHER than your local network IP.. if you are doing from HOME, you need HOME PUBLIC IP.. = if you don't have static IP with your ISP then you can not use it respectively since IP can change depending on ISP at home.
WAN destination is feature to secure the IP (REMOTE) so that ONLY remote IP can use this ...
