lippy
May 06, 2012Aspirant
FVS318N Can’t Port Forward
Okay. I’m throwing the uncle card. I can’t get the FVS318N to port forward. I’m trying to forward port 1723 (PPtP) for VPN into our server. I get out, I hit the server, but it is being blocked on t...
adit
Jan 22, 2013Mentor
It could have had the wrong default gateway programmed. It could have also been a problem if you had 2 NIC's enabled with which both had default gateway settings programmed.
