joshw1234's avatar
joshw1234
FVS318N Disable Remote Management
Getting to the point, I am trying to run a web server on my network, which will use ports 80 and 443 (. I can get the web server to work by forwarding other ports that I've tested, such as 1001.   ...
  • joshw1234's avatar
    joshw1234
    Apr 02, 2017
    DaneA,
    I tried disabling the login for all users (other than admin) from the WAN interface initially.
    I was able to solve the problem by deleting all port forwarding rules (including UPnP), then re-forwarding the ports via UPnP.
    Thanks for your help!
ProSupport for Business
