blackbox
Jul 10, 2017Aspirant
FVS318N firmware 4.3.3-6 not allowing more than 8 wireless connections
Back in 2015 users reported that no more than 8 devices could connect on FVS318N. You can find the old discussion here https://community.netgear.com/t5/Business-Wireless/FVS318N-firmware-4-3-3-5-not-...
- Aug 03, 2017
At the end pressing the reset button for so much time factory reset everything and even the firmware upgarde worked after that.
Instead of doing all the configurations all again I gave it a go and restore my configurations and I now have 11 devices connected which seems the problem is now resolved.
blackbox
Aug 02, 2017Aspirant
DaneArouter is now directly connected to the PC, I cleared browser's cache and still did not not work. I am going to try the TFTP way. If that does not work either I will have to factory reset the unit and give it a go hopefully all this at the end wont brick the device.
blackbox
Aug 03, 2017Aspirant
- DaneAAug 03, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad to know that you were able to update the firmware of your FVS318N to the latest version. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
