WMC
Feb 13, 2016Follower
FVS318N requires periodic reboot
I reviwed the community article titled FVS318N router keeps dropping network connectivity, which was closed due to inactivity. I'm having the same problem where the router runs for about a week or s...
JohnRo
Feb 16, 2016NETGEAR Employee Retired
Hello WMC,
Welcome to the community!
I suggest opening a support case for this one so it can be isolated properly. Were you able to download the logs and see anything that is out of the usual? I have seen a case logged similar to the issue you are having but it is better to get the techs involved so that we know if it is the same issue.
Looking forward to your response.
Thanks,
- joe_schmoFeb 25, 2016Tutor
You ever get this sorted? I just upgraded the FW this weekend and now I have the same problem as you.
- JohnRoFeb 26, 2016NETGEAR Employee Retired
Hello joe_schmo,
What firmware version are you using on your FVS318N? I cannot confirm that there is a memory leak issue since I don't see one reported on our logged issues. Still waiting for @VMC to open a support case for this one. Can you provide me some details about your network and did the issue started right after updating?
Thanks,
- joe_schmoMar 06, 2016Tutor
Thanks for reaching out....! After owning this fvs31n (2nd one), plus a gs752tp, 3 readynas, wifi routers, etc, I was starting to lose faith... So tody, I got anoter out of memory exception. The log is here: http://pastebin.com/V7zfNCfw
Please take a look and see what you think...
