WMC
Feb 13, 2016Follower
FVS318N requires periodic reboot
I reviwed the community article titled FVS318N router keeps dropping network connectivity, which was closed due to inactivity. I'm having the same problem where the router runs for about a week or s...
joe_schmo
Feb 25, 2016Tutor
You ever get this sorted? I just upgraded the FW this weekend and now I have the same problem as you.
JohnRo
Feb 26, 2016NETGEAR Employee Retired
Hello joe_schmo,
What firmware version are you using on your FVS318N? I cannot confirm that there is a memory leak issue since I don't see one reported on our logged issues. Still waiting for @VMC to open a support case for this one. Can you provide me some details about your network and did the issue started right after updating?
Looking forward to your response.
Thanks,
- joe_schmoMar 06, 2016Tutor
Thanks for reaching out....! After owning this fvs31n (2nd one), plus a gs752tp, 3 readynas, wifi routers, etc, I was starting to lose faith... So tody, I got anoter out of memory exception. The log is here: http://pastebin.com/V7zfNCfw
Please take a look and see what you think...
- DaneAMar 07, 2016NETGEAR Employee Retired
Hi joe_schmo,
Were you able to perform a factory reset on the FVS318N after you have upgraded the firmware? If not yet, kindly perform a factory reset then reconfigure the FVS318N from scratch and check if same problem occurs. It is recommended to have any device be reset to factory default setting after a successful firmware upgrade.
Also, for the firewall logs to be analyzed, kindly open an online case with NETGEAR Support here and attach the firewall logs.
DaneA
NETGEAR Community Team
- joe_schmoMar 08, 2016Tutor
You are kidding! I mean, re-doing everything from scratch would take forever, especially my DHCP reservations. Argh
