WMC
Feb 13, 2016Follower
FVS318N requires periodic reboot
I reviwed the community article titled FVS318N router keeps dropping network connectivity, which was closed due to inactivity. I'm having the same problem where the router runs for about a week or s...
joe_schmo
Mar 07, 2016Tutor
Thanks for reaching out....! After owning this fvs31n (2nd one), plus a gs752tp, 3 readynas, wifi routers, etc, I was starting to lose faith... So tody, I got anoter out of memory exception. The log is here: http://pastebin.com/V7zfNCfw
Please take a look and see what you think...
DaneA
Mar 07, 2016NETGEAR Employee Retired
Hi joe_schmo,
Were you able to perform a factory reset on the FVS318N after you have upgraded the firmware? If not yet, kindly perform a factory reset then reconfigure the FVS318N from scratch and check if same problem occurs. It is recommended to have any device be reset to factory default setting after a successful firmware upgrade.
Also, for the firewall logs to be analyzed, kindly open an online case with NETGEAR Support here and attach the firewall logs.
DaneA
NETGEAR Community Team
- joe_schmoMar 08, 2016Tutor
You are kidding! I mean, re-doing everything from scratch would take forever, especially my DHCP reservations. Argh
- DaneAMar 09, 2016NETGEAR Employee Retired
Hi joe_schmo,
I apologize for this. However, as I have mentioned, it is recommended. It is also a way to isolate the problem.
DaneA
- joe_schmoMar 09, 2016Tutor
No worries... I did this and upgraded to the latest firmware...
Some things to note/ask:
I am in stealth mode. I have two ports being forwarded, port 1000 UDP and port 1001 TCP. If I do an external port check, it shows port 1000 closed but port 1001 open.- Is that what should happen? Is there a way to make 1001 appear to be stealth?
Second, does this log look OK? http://pastebin.com/BuaHjRhx
Specifically: HTB: quantum of class 10002 is big. Consider r2q change.
and " Loaded VPN Configuration " ( I don't have VPN configured, so why is that there? ).
