WMC
Feb 13, 2016Follower
FVS318N requires periodic reboot
I reviwed the community article titled FVS318N router keeps dropping network connectivity, which was closed due to inactivity. I'm having the same problem where the router runs for about a week or s...
rlcarper
May 24, 2016Tutor
I believe that the packet capture would be so big that the memory of the router would be already full before finishing the capture.
how about the analysis of log entries? They clearly indicate a memory leak...
JohnRo
May 30, 2016NETGEAR Employee Retired
Hello rlcarper,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- rlcarperJun 08, 2016Tutor
Hello,
The issues is not resolved. When I enabled teh PCAP to run, the resulting PCAP did not contain all of the generated traffic. So the PCAP tool is of little/ no use here.
- DaneAJun 09, 2016NETGEAR Employee Retired
Hi rlcarper,
Firmware v4.3.3-8 has just been released for FVS318N. For the meantime, kindly try to update the firmware of your FVS318N to v4.3.3-8. Be sure to reset the FVS318N back to factory default settings after upgrading the firmware then reconfigure it from scratch. Observe if same problem occurs.
DaneA
NETGEAR Community Team
