WMC
Feb 13, 2016Follower
FVS318N requires periodic reboot
I reviwed the community article titled FVS318N router keeps dropping network connectivity, which was closed due to inactivity. I'm having the same problem where the router runs for about a week or s...
SamirD
Feb 15, 2017Prodigy
I was watching this thread with keen interest as I never saw higher than 50Mbps on all 3 of my FVS318Ns and was hoping that someone found a solution.
Here's the solution that worked for me, and I tested it in a lab scenario for 48 hours passing over 100GB in data from the lan to wan, and then letting it sit for a day, and it still worked with speeds of 179-180Mbits from wan to lan (fastest our Internet go). Upgrade to firmware 4.3.4-1. This upgrade as so far solved any speed issues. I plan to roll it out to all our FVS318Ns. I don't know what else might be broken though, so watch for any other issues on other features you may be using such as port forwarding, dhcp, vlans, etc. Good luck!
rlcarper
Feb 15, 2017Tutor
Hi Samird,
I am using 3 SSID's on my Wifi in this router and several VLANs. have inbound port forwarding and outbound rules (default rule = deny)
used to have VPN as well and trafic meter enabled, buit VPN's no longer needed and trafficmeter aparantly reduces performance to 30/30.
What setup did you use to test 48 hours?
Running
| Firmware Version: | 4.3.4-2 |
now
- SamirDFeb 15, 2017Prodigy
I left it in bone stock setup besides changing the subnet of the lan to keep it from conflicting with an existing lan. I ran the dslreports speed tests as they consistantly would max out our connection properly.
I tested a few times after setup.
Then because this was a local lab setup, I ran an iperf to a system on the 'wan' for 24hrs reporting once every minute (iperf -c 192.168.1.11 -t86400 -i60). Once it passed that test, I again ran a speedtest and then called it good.
The next test was putting it into production where the Internet is a 60/5 connection. Normally it would be right at the 60 mark. It tested 65/5.
I would try testing with all the wifi disabled. The wifi on the 318N is terrible. I'm about to get a 802.11ac AP as 802.11ac is faster than the N anyways.
As far as the port forwards, I didn't try any.
Hope this helps.
- rlcarperFeb 15, 2017Tutor
I have an additional Unifi AC-Lite connected. I could try disabling the wifi on the 318N completely, but then what use is the product if it can only go fast with most features disabled.
- SamirDFeb 16, 2017Prodigy
I'd try disabling the internal wifi and see if that fixes it.
As far as what's the good if it doesn't work 100%? It's 10x cheaper than a product that does. And all the routers in this price range are semi-broken like this. But you can usually make a solution using one for 1/4 the cost of an enterprise-class system which would work just as it says (but there's always still some caveats).
To give you an idea of how much more cost-wise, a watchguard t50--which can do about the same as the FVS318N and still doesn't have wifi--costs around $800 on the cheap end.
