scott_1971
Mar 30, 2015Novice
FVS318N to Netgear PRO Safe Client - IPSEC
I have successfully setup an IPSEC tunnel between laptop and my FVS318N at office. I need to access specific sites from ISP off FVS318N via the VPN (as the WAN static IP is on a customer's white li...
RX
Mar 30, 2015Luminary
Setting up firewall rules doesn't take effect on VPN tunnels. Its the IKE and VPN policies that govern the VPN connection.
Firewall rules are meant to take effect on the WAN connection and of course that is via the WAN port. :)
Are you remotely connected to a PC within the LAN of your FVS318N via the VPN connection and you want to go online using the PC that you are remotely connected to, am I right?
