scott_1971
Mar 30, 2015Novice
FVS318N to Netgear PRO Safe Client - IPSEC
I have successfully setup an IPSEC tunnel between laptop and my FVS318N at office. I need to access specific sites from ISP off FVS318N via the VPN (as the WAN static IP is on a customer's white li...
fordem
Mar 30, 2015Mentor
You should be able to configure the VPN policy for "full" tunneling - which will force all traffic from the client through the tunnel and get to the internet that way, unfortunately, I no longer use the Netgear VPN client, so I can not provide specific steps.
You'll need to change the traffic selection section of the VPN policy (possibly at both ends) where you specify the LAN network behind the FVS318 so that it says any.
