scott_1971
Mar 30, 2015Novice
FVS318N to Netgear PRO Safe Client - IPSEC
I have successfully setup an IPSEC tunnel between laptop and my FVS318N at office. I need to access specific sites from ISP off FVS318N via the VPN (as the WAN static IP is on a customer's white li...
scott_1971
Mar 31, 2015Novice
The VPN Client Lite does have ability to disable split tunnel which I have configured.
The Tunnel opens on client with IP 192.168.4.2/255.255.255.0, the client does not show a Default Gateway.
I can ping the FVS and most devices on the Lan thru the tunnel.
I can not ping the VPN client from LAN computer (192.168.3.x)
