scott_1971
Mar 30, 2015Novice
FVS318N to Netgear PRO Safe Client - IPSEC
I have successfully setup an IPSEC tunnel between laptop and my FVS318N at office. I need to access specific sites from ISP off FVS318N via the VPN (as the WAN static IP is on a customer's white li...
scott_1971
Mar 31, 2015Novice
fordem - Thanks for your timely response. I understand the Tunnel is open and good, so here is my problem.
I need to use the FVS WAN side to access internet thru the tunnel. My WAN IP is static and on "white list" of a customer. What firewall/security rules do I need to set on the FVS (and/or tunnel client computer) to be able to access the internet thru the FVS?
Really appreciate your help.
R/scott
R/scott
