scott_1971
Mar 30, 2015Novice
FVS318N to Netgear PRO Safe Client - IPSEC
I have successfully setup an IPSEC tunnel between laptop and my FVS318N at office. I need to access specific sites from ISP off FVS318N via the VPN (as the WAN static IP is on a customer's white li...
fordem
Mar 31, 2015Mentor
Full tunneling is what you need to set up.
With split tunneling, the traffic is split so that only the traffic for the LAN at the far end through the tunnel, and every thing else goes to the internet at the VPN client location; with full tunneling, ALL the traffic is sent through the tunnel, so the internet can only be reached by going through the internet connection at the far end.
