SamirD
Feb 15, 2017Prodigy
FVS318N VPN Tunnel from Single Endpoint to 2 VLANS
I think I know how to do this, but wanted to confirm before attempting to make the configuration changes. I currently have 1 VLAN on the 318N. This is connected to another VPN router via a site-...
- Feb 26, 2017
Correct, if what you're doing is looking to add a second subnet to an existing IKE, just add another VPN policy, and select the same IKE policy. I had 4 subnets configured with the same IKE policy from the Netgear to a Cisco ASA5506 with no issues.
EDIT surprised at the response delay here , this is a pretty simple VPN configuration. It's just a single phase 1 installation with multiple phase 2s.....
JohnRo
Feb 16, 2017NETGEAR Employee Retired
Hello SamirD,
I cannot confirm since I have not tested it myself (Will probably try on a later time). In theory, this setup should work since they have the same endpoint. The IKE policies will be the same for both VLANs however, I'm thinking this would only use one connection at a time. I'll inquire this one just to make sure.
Thanks,
- SamirDFeb 16, 2017Prodigy
Yikes! Only one tunnel at a time would be a problem. Let me know what you find out and what a workaround would be (new IKE policy?).
