SamirD
Feb 15, 2017Prodigy
FVS318N VPN Tunnel from Single Endpoint to 2 VLANS
I think I know how to do this, but wanted to confirm before attempting to make the configuration changes. I currently have 1 VLAN on the 318N. This is connected to another VPN router via a site-...
- Feb 26, 2017
Correct, if what you're doing is looking to add a second subnet to an existing IKE, just add another VPN policy, and select the same IKE policy. I had 4 subnets configured with the same IKE policy from the Netgear to a Cisco ASA5506 with no issues.
EDIT surprised at the response delay here , this is a pretty simple VPN configuration. It's just a single phase 1 installation with multiple phase 2s.....
train_wreck
Feb 26, 2017Luminary
SamirD
Mar 14, 2017Prodigy
So I just ran into a problem with this configuration after my ISP changed my endpoint IPs without telling me. >:|
I am not able to update the endpoint IPs on either of the VPN policies to the new IP. It gives me the error of 'Can't share IKE policy with different remote/local endpoint'. I've tried disabling the VPN policies and that doesn't help. I don't want to delete the policy and have to rebuild it from scratch. There has to be another way to update this simple bit of information. Any ideas?
- SamirDMar 14, 2017Prodigy
Scratch this. I had the IP off one digit on one of the vpn profiles. Everything worked fine after it was changed to the correct IP. :D
