SamirD
Feb 15, 2017Prodigy
FVS318N VPN Tunnel from Single Endpoint to 2 VLANS
I think I know how to do this, but wanted to confirm before attempting to make the configuration changes. I currently have 1 VLAN on the 318N. This is connected to another VPN router via a site-...
- Feb 26, 2017
Correct, if what you're doing is looking to add a second subnet to an existing IKE, just add another VPN policy, and select the same IKE policy. I had 4 subnets configured with the same IKE policy from the Netgear to a Cisco ASA5506 with no issues.
EDIT surprised at the response delay here , this is a pretty simple VPN configuration. It's just a single phase 1 installation with multiple phase 2s.....
SamirD
Mar 14, 2017Prodigy
So I just ran into a problem with this configuration after my ISP changed my endpoint IPs without telling me. >:|
I am not able to update the endpoint IPs on either of the VPN policies to the new IP. It gives me the error of 'Can't share IKE policy with different remote/local endpoint'. I've tried disabling the VPN policies and that doesn't help. I don't want to delete the policy and have to rebuild it from scratch. There has to be another way to update this simple bit of information. Any ideas?
SamirD
Mar 14, 2017Prodigy
Scratch this. I had the IP off one digit on one of the vpn profiles. Everything worked fine after it was changed to the correct IP. :D
