Retired_Member's avatar
Retired_Member
Jan 24, 2016
FVS318N WAN to LAN throughput and performance
Hi,
Recently upgraded my DSL connection 8M/1M to Cable 130M/30M. I changed from using PPoE to direct connection and modified the MTU size back to the default 1500 as per the provider recommendation. I have some 30 outbound rules and one site to site VPN to a FWG114Pv2.
When I connect iover wired gigabit ethernet to the LAN port. I get speed tests results limited to 30M down and 30 M up. When I disconnect the WAN cable of the FVS318N and directly connect the Cable modem I get the promised 130Meg down and 30 Meg up. I backed up the FVS318N config and ran a factory default. Speed tests using the FVS318N result in 130Meg down and 30 meg up. This puts the
trouble shooting effort into the config differences. Im running the following version of the software. During speedtests and downloads, the Webgui is unresponsive.
System Name:FVS318N
Firmware Version:4.3.3-6
As the FVS318N is rated to be 250Mbps LAN-WAN performance, I'm wondering what may be affecting the throughput so much.
Hope that you can help!
I have 31 rules outbound, all have logging enabled, but disabling logging doesnt seem to affect performance
I have 10 inbound rules. all logging enabled
VLANs: 3 defined, including default
SSIDs: 3
I diffed the config backup files between the default and my config:
Despite the web gui reporting Autosense on the WAN port, this is in my config:
PortMgmt[9]["DuplexMode"] = "0"
PortMgmt[9]["AutoNegEnable"] = "1"
PortMgmt[9]["PortSpeed"] = "10"
the default config shows:
PortMgmt[9]["DuplexMode"] = "1"
PortMgmt[9]["PortSpeed"] = "1000"
the 10 Mbit port speed doesn't make sense and would actualy limit the trouhhput to 10 Mit, but I'm getting 30 Mbit..so this should not affect it.
I have syslog enabled:
sysLogInfo[1]["Enable"] = "1"
sysLogInfo[1]["_ROWID_"] = "1"
sysLogInfo[1]["severity"] = "8"
sysLogInfo[1]["serverName"] = <removed>
What's more: Attack checks. The default configuration shows that the webgui and manual report TCP and UDP flood protection are enabled, bnut the config fiel shows otherwise:
AttackChecks[1]["TcpFlood"] = "0"
AttackChecks[1]["ExternalPingAddress"] = "0.0.0.0"
AttackChecks[1]["StealthMode"] = "1"
AttackChecks[1]["UdpFlood"] = "0"
AttackChecks[1]["DropInvalidResetPacket"] = "1"
AttackChecks[1]["PingReplyOnLan"] = "0"
AttackChecks[1]["DnsProxy"] = "0"
AttackChecks[1]["IpsecPassthrough"] = "1"
AttackChecks[1]["_ROWID_"] = "1"
AttackChecks[1]["udpConnLimit"] = "25"
In my custom config:
AttackChecks[1]["TcpFlood"] = "1"
AttackChecks[1]["ExternalPingAddress"] = ""
AttackChecks[1]["UdpFlood"] = "1"
AttackChecks[1]["udpConnLimit"] = "100"
diabling attack checks does not change the throughput however. has been tested.
Logging, nothing fancy
FirewallLogs[1]["LANToDMZAccept"] = "0"
FirewallLogs[1]["BandwidthLimitLogs"] = "0"
FirewallLogs[1]["LANToDMZDROP"] = "0"
FirewallLogs[1]["LANToWANAccept"] = "1"
FirewallLogs[1]["SessionLimitLogs"] = "0"
FirewallLogs[1]["DMZToLANAccept"] = "0"
FirewallLogs[1]["DMZToWANDrop"] = "0"
FirewallLogs[1]["SourceMACFilter"] = "0"
FirewallLogs[1]["LANToWANDrop"] = "1"
FirewallLogs[1]["WANToDMZAccept"] = "0"
FirewallLogs[1]["WANToLANDrop"] = "1"
FirewallLogs[1]["WANToDMZDrop"] = "0"
FirewallLogs[1]["WANToLANAccept"] = "1"
Hope that anyone knows the answers to this riddle.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi noibla,
    Welcome to the community! :)
    When you did a factory reset on the FVS318N, did you try reconfigure it from scratch and check if same problem occurs?  If not, kindly try to backup the setting then perform a factory reset then configure the internet connection from scratch (no firewall rules yet just set it up for internet access).  Then, check if you will be getting 130Mbps download and 30Mbps upload speeds.
    I look forward to your response.
    DaneA
    NETGEAR Community Team
    • Retired_Member's avatar
      Retired_Member
      Hi DaneA,
      As indicated I did a factory reset and configured minimal settings to bring the Internet connection online. With these settings I was getting the 130M and 30 M speeds. I can send the default (minimal config) and the original config (password sanitized for review).
      Would it halp to conenct the serial console to do command line debugging?
      • DaneA's avatar
        DaneA
        Hi noibla,
        With the minimal config, kindly set up a box-to-box VPN to the FWG114Pv2 then check if you would still get 130Mbps download and 30Mbps upload speeds.  No firewall rules yet.
        About sending the minimal config file and the original config file, I encourage you to open an online case with NETGEAR Support.  You can attach the config files on the online case for it to be analyze.
        DaneA
ProSupport for Business
