Anonymous
Jan 24, 2016FVS318N WAN to LAN throughput and performance
Hi, Recently upgraded my DSL connection 8M/1M to Cable 130M/30M. I changed from using PPoE to direct connection and modified the MTU size back to the default 1500 as per the provider recommendati...
Anonymous
Jan 25, 2016Enabling logging without any rules drops the performance to 90 MB down. could be affected by the Resolved DNS names log setting.setting DNS resolved names ot 0 gets the 130 MB back
therSystemLogs[1]["VPNLogs"] = "1"
OtherSystemLogs[1]["LoginAttemptsLogs"] = "1"
OtherSystemLogs[1]["SecureLoginAttempts"] = "1"
OtherSystemLogs[1]["ChangeOfTimeByNTPLogs"] = "1"
OtherSystemLogs[1]["ResolvedDNSNames"] = "1"
OtherSystemLogs[1]["WANStatusLogs"] = "1"
OtherSystemLogs[1]["RebootLogs"] = "1"
OtherSystemLogs[1]["_ROWID_"] = "1"
OtherSystemLogs[1]["DhcpServerLogs"] = "1"
FirewallLogs[1]["LANToWANAccept"] = "1"
FirewallLogs[1]["LANToWANDrop"] = "1"
FirewallLogs[1]["WANToLANDrop"] = "1"
FirewallLogs[1]["WANToLANAccept"] = "1"
Results in a mixup of kernel logs that seem to be overwriting lines:
Mon Jan 25 21:06:45 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data
Mon Jan 25 21:06:20 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:05:50 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:05:20 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:04:50 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:04:20 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:03:50 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:03:20 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:02:49 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:02:19 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:01:49 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 21:01:49 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Mon Jan 25 21:01:19 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 21:01:04 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 21:01:04 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Mon Jan 25 21:00:34 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 21:00:34 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Mon Jan 25 21:00:24 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 21:00:24 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Mon Jan 25 21:00:19 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data uplex, FC-Rx=0, FC-Tx=0 quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 20:59:59 2016(GMT+0000) [FVS318N][Kernel][KERNEL] MAC1: S/W AN link up to 1000Mbps, Full-duplex, FC-Rx=0, FC-Tx=0 quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 20:59:44 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 20:59:44 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Mon Jan 25 20:59:19 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 20:58:29 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 20:58:29 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Mon Jan 25 20:58:24 2016(GMT+0000) [FVS318N][Kernel][KERNEL] <sppe_cmd_arp> Fail to delete IPv4 ARP entry r2q change.
Mon Jan 25 20:58:19 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 20:57:54 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 20:57:54 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Mon Jan 25 20:57:44 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 20:57:44 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Mon Jan 25 20:57:19 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 20:56:19 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 20:55:19 2016(GMT+0000) [FVS318N][Kernel][KERNEL] Should overwrite TID here for NULL data ider r2q change.
Mon Jan 25 20:49:59 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change. ULL data
Mon Jan 25 20:49:59 2016(GMT+0000) [FVS318N][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
2M
Jun 08, 2016Initiate
did you ever get a fix? i have same issue.
